You can just turn the screw. No CONSULT needed.wzntha wrote:also, for adjusting the idle, is it just as simple as turning the screw? in the fsm, doesn't it say that you need a consult and have to follow some sort of procedure? i've been wanting to adjust my idle when the ac is on cause the rpms drop instead of rise when the ac in on.
