240guyNY »
https://forums.nicoclub.com/240guyny-u32190.html
Mon Mar 06, 2006 9:38 am
Well right now the vacuum system really isnt run the right way, and i know that. Also, just the boost gauge from the profec b is T'd into the FPR. Then, on the other nipple from the TB is the Boost solenoid, BOV and another Boost Gauge line for the autometer, and wastegate. It's way to much, Iknow and thats why im getting a vacuum fitting welded onto my hot pipe. So basically my real problem is that i have 2 boost guages, where should i T the second one off of. Can i just use the unused nipple on the bottom of the Throttle Body.
Also, does anyone know where i can get an aluminum bung to have welded on?Thanks
