SHIEF wrote:Keep your EGR, otherwise you'll throw codes, possibly mess up your O2 sensor, run rich. You'll have to get the ECU re-mapped for a car w/o egr....not worth it. As for the carbon canister, you probably won't pass emissons...that's it. Just plug the vac lines, and the line going into the bottom of the canister, or remove that metal line completely plug it underneath the car (next to your AC box rubber vent tube).
240kid wrote:think about it, exhaust cant be burned, it has almost no o2. when ecu sends close signal to egr, then engine will run normal. when it says open, then it will put the ammount of fuel in for the air/exhaust mixture, less fuel than just air because like i said, the exhaust has almost no o2. with the egr removed, there will be just air but the comp. will think there is exhaust in the air, giving less fuel and vola, your runing lean.without the canister, the pressure in the tank will build up. to keep the tank from exploding, the fuel cap will vent some vapors out. and you have no emmisions anyway, so remove it if you want.
Your tank won't "exlplode". I dunno where you got that (if that's what your saying there).240kid wrote:think about it, exhaust cant be burned, it has almost no o2. when ecu sends close signal to egr, then engine will run normal. when it says open, then it will put the ammount of fuel in for the air/exhaust mixture, less fuel than just air because like i said, the exhaust has almost no o2. with the egr removed, there will be just air but the comp. will think there is exhaust in the air, giving less fuel and vola, your runing lean.without the canister, the pressure in the tank will build up. to keep the tank from exploding, the fuel cap will vent some vapors out. and you have no emmisions anyway, so remove it if you want.
