vacuum lines
cmilla
Car: 1995 240sx se
anyone know of where i can find a good pic on the vac lines. i need them for the bov, boost controller, boost gauge. i got a few figured out i think but anything to help me double check would be greatly appericated. thanks ahead of time!
cmilla
Car: 1995 240sx se
forgot to add its a s15
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Pretty sure it's the same as an S13. The big one goes to your cold pipe. The rest of them don't really matter. A vacuum source is a vacuum source. One to your FPR. One to your BOV. One to your boost gauge. One to your boost controller. You'll most likely have to T some unless you have an aftermarket intake manifold.
