Vacuum lines, solenoid, and pilot bearing questions(KA24DE)
RCG_Savage
Car: '92 240sx fastback
Vacuum lines.first question is the vacuum that are under the throttle body.In this picture there are two unconnected pipes do these connect to each other or hook up somewhere? By there location Im assuming they need to be connected.http://img.photobucket.com/alb...3.jpg
Also where do these 4 hoses hook up? They were never connected when I got the car so I am cluesless as where to hook these up. THe one with the T connecter that has a larger tubing coming off seems like it hooks into the intake how ever.http://img.photobucket.com/alb...3.jpgh ... lb...1.jpg
This solenoid on the beck was broken as well when I got the car. Is there any place I can get a replacement or a substitute I could use?http://img.photobucket.com/alb...8.jpg
I have an exedy clutch kit which came with clutch, pressure plate, throw out bearing and pilot bearing. How ever the pilot bearing is too large for the hole. Could I've gotten the wrong one some how?
180fan
Car: 89 fastback
did you pull the pilot bushing that was in there out?
you can pull up the complete vac diagrams ala the red button up top labeled "search".
