Vacuum Lines..Searched Already
Trppen37
Car: CA18DET
Ok so Im at the vacuum line connection portion of hooking up the engine.. Theres one small vacuum under/before the throttle body/at the throttle body... which one does it hook up to... from reading sillbeers site it goes to the carbon canister..I dont have one but I can I use it to hook it up the IACV behind the Stock Fuel Regulator?? There are other vacuum lines like On after the throttle body and Two in the rear... which one Do i hook up to my Boost Gauge as well as A Manual boost controller..and which one do I hook up to the Fuel Regulator and Turbo.
Where to hook up the:Boost GaugeManual Boost ControllerFuel RegulatorTurboIACV/ Intake Manifold Butterflies..
thanks again..after this...I hope the engine runs now...
kim
Car: 90 240sx, 97 M3
Are you talking abou the 4 lines that are near the rear of the intake manifold? Or are you talking about the ones right next to the throttle body? I too need some info about the 4 rear vacuum lines near the rear of the Int. Manifold.
Trppen37
Car: CA18DET
to make it easier..im talking about all the vacuum lines associated with the intake manifold..
pulsar gtr
Car: NISSAN VEHICLES
well, the thin one on the back of the intake you can connect it to the turbo wastegate actuator.The one on the side of the intake goes to the IACV beside the fpr or to the fpr, doesn't matter, The big one on the back of teh intake goes to your brake booster.The one under the throttle body you can use for the fpr
PULSAR GTR
Trppen37
Car: CA18DET
thanks pulsar your the man!
