GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Wed Jul 30, 2008 4:35 am
Hose #8 connects to an opening or short piece of metal tubing on underside of the plastic ducting assembly that connects the MAF/Air Filter assembly to the passenger and driver side Throttle Bodies. It is shielded/covered, looking slightly larger diameter than the others (view A). If an end of the hose is broken off , you may have lost some hose and the piece of metal tubing that connects it to the hole in the underside of the plastic/rubber ducting. Here's a photo of Hose #8
Hose #7 connects the EGR control valve to the metal tubing on the underside of the passenger side Throttle Body
Hose #6 is that short elbow-like piece of tubing connecting the EGR control valve to the metal tubing on the underside of the plenum
Hoses #6 (top left), #7 (top right) and #8 (bottom center) are visible in the photo below.
Hose #5 gets things closer to the EGR valve and Hose #4 gets things all the way to the EGR valve, and should have a bit of rubber tubing shielding it. Hose #5 is shielded too and is really buried under the passenger side corner of the plenum.
Modified by GerryO at 8:42 AM 7/30/2008
