SPIRONIUM »
https://forums.nicoclub.com/spironium-u36370.html
Thu Apr 20, 2006 4:23 pm
The ONLY small size vaccuum line needed is for the fuel pressure regulator. IF you still have the secondary butterflies the SCV Actuator needs to be plugged in as well. Everything else that has a small vaccuum line attached to it can be trashed. The metal small vaccuum line group thingy can be trashed. The only vaccuum lines i have are for the FPR, idle air controller tube, crankcase/valve cover vents and brake booster of course. This is for a DOHC but the single cam has the same junk. So far there are no codes (doesn't seem right i'll check the ecu again now that i have more miles in its memory), no check engine light, and the engine runs well, good gas mileage. In reality it is a bad idea to remove emmisions if your state does testing, and there is no significant benefit from removing all of this stuff other than having a slightly cleaner looking engine bay.
