vacuum line help
USDM_OneVia
Car: Racing
Got the motor up on the engine stand and I have a few vacuum lines that I don't know where they go. If you look in the picture below you will see them circled. There are a cluster of 3 on the back of the intake manifold near the rear of the motor that I do not know where they go to. I traced them and the top one goes to the FPR and has a red band. The second one goes to the EGR and has a blue band. The bottom one goes to the Wastegate Solenoid and has a green band. Any help?
Then there is a cluster up by the throttle body. One is a larger hose and is just cut off. Then there are the 2 smaller ones above it. One goes from the intake manifold and then is cut. And the other one is on the throttle body then it is cut. I can take better pics if neccessary.
Thanks for the help guys and gals!
Joe
Doogz
Car: '89 240sx coupe
The bottom ones should go the carbon canister thing and the other ones on the side, i just plugged em and they are doing just fine. They actually go to some big vacuum assembly that i didn't feel like messing with.
slw240sx
Car: 1990 Ca18det 240sx Hatch
damn it one of these days ill get off to come down i swear!!
today was so nasty and rainy i decided to stay near home seeing as im runing slicks in the rear. i decided it was time to play with some new toys. they are in another thread around here!
USDM_OneVia
Car: Racing
slw240sx wrote:damn it one of these days ill get off to come down i swear!!
And the Bengals will have a winning season too... :)
Joe
