DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Wed Jan 31, 2018 7:41 am
The best DIY coupler I cam up with is a plumbing plug you can easily get at a Hardware store, and where I was JUST able to drill a hole for an airline fitting into in which to attach your compressor. It has a solid rubber disk that when you screw it tight, expands to fit the opening on a hardpipe (dual intake as I have) or the MAF opening of the OEM 1 to 2 opening soft pipe connection. With your compressor set to only create and pump 5-6 psi, hook it up and you can then go around and check various spots with anything that would indicate airflow, including your ear. Be aware that the intake valves on a cylinder or two may be open and give a faint internal hissing sound, but that will be from inside the engine and if that's all you hear, you have a different issue such as failed turbo or other turbo issue more likely...as I did, and which required new turbos.
