Vacuum Leak
dle_240
Car: 1990 300zx 2+2
In the past couple of days I have noticed, what I think is, a vacuum leak. I already had one vacuum leak that would make my idle go up and then back down when I started the car. Now the idle rpm's have gone up and the car is running rough. Can someone tell me the best way to find the vacuum leaks?
MAXXTHRUST
Car: 2 EA. 1990 1991 NISSAN 300 ZX tt AND MY FAVORITE 1993 PORSCHE 928 GT
In case this problem still plagues you.Start engine, let idle, spray down every hose one at a time , If the engine speeds up you have found the leak. if you have vacumn booster for the clutch just pinch off hose to check it also. GOOD LUCK.
