Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Mon Oct 30, 2006 6:15 pm
I'm guessing you checked all the hose connections?
Do you have an oil catch can? sunlitsand's post made me think of this;
As to your vacuum leak, check 2 things, 1 all the connections for the catch can. 2 start the car (with hood up) and rev it a little. Watch the hose from the PCV valve to the CC and from the CC to the intake. Does the hose collapse? Also, when I put my CC on I immeadiately (sp?) noticed a louder sucking sound. An easy way to check for leaks on the CC tubing is to light a cig and hold the cherry close to the ends of the hoses. If the smoke looks to be getting sucked in, you found your leak!
If you don't have a catch can, disregard the above.
Modified by beancooker at 8:27 PM 10/30/2006
