RedSubdivisions »
https://forums.nicoclub.com/redsubdivisions-u54970.html
Mon Aug 10, 2009 1:54 pm
so my shop manager and I are stumped about my car. I just rebuilt my KA up and down (new rings, seals, HG, the works) and when I put her back together she fires right up! Awesome! But the catch is that the car idles a little off when the MAF is unplugged, but she still seems to keep an idle. However, I plug the MAF in and she stays on, but dies out within seconds. I have blocked off my EGR, made sure there was no vacuum leaks upon assembly of the intake manifold.
Now, I'm thinking it's the MAF wiring issue because of two things:
1) when I boosted my KA (and when it failed miserably, btw), I had a "friend" hack my ECU white wire to be used with the SAFC. well, after returning my car back to stock, he used a crimp to put my MAF wires back together. now because those wires are so temperamental, would that cause my car to stall out when I plug my MAF back in? better yet, would ANY part of the wire exposed make that much of a difference to where my car won't hold an idle? and no, my MAF is not bad. I checked it and it's 100% good to go.
and 2) if it was a vacuum issue, then why is the car still running after I unplugged the MAF? I mean, if it was a vacuum issue, that car would die out with or without the MAF if I'm not mistaken. This is just a guesstimate so I don't expect myself to be even remotely right. lol
any input is appreciated, guys. you've helped me out for the past few years.
