Vacuum leak in a/c hose, in cabin
SmokeyMCN
Car: 93' 300zx NA Convertible
91' 300zx TT
So I've been posting about a vacuum leak for a while, first I posted and everyne said it was my brake booster if I could hear the leak in the cabin, I changed the booster and still the leak is there.
I hear the leak in the cabin, Now everyone is telling me it can only be the A/c vacuum lines that go into the car,
Can anyone help me out with where these hoses are and how I can access them / change them?
nissanfreak12
Car: 92 300zx 2+2 TT
We don't have A/C vacuum lines, ours are all electronic. Do you have an aftermarket boost gauge inside the car? Electronic boost controller? Booster for the clutch?
Only vac we have in the car or source that has vac to it is the brake booster for the NA and clutch and brake booster on the TT, stock. When does the hissing occur? Are you sure its a vac leak? does the car run different/bad?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
I think I have a similar thing going with mine. When the A/C is on, it'll hiss for about 5 seconds, stop for about 10, and then hiss again. I never really cared to check on it, cause the A/C blows cold, never smell any refrigerant, and never had any stumble or performance issue.
