Vacuum Leak....how to find it???
kpc_0721
Car: 1991 240sx hatchback
Hey just wondering is there a way to check the vaccum pressure and check for leaks because I think I may have a vacuum leak somewhere but I cant seem to find it?
coolbone28
Florida240sx
I use a pvc cap that I drilled a hole in.
blinkshome
Car: 95 240 ka24det
if you have an undisclosed vac leak try spraying some integral parts of the vac system with carb cleaner. the motor idle should race when you find it. better done on a cold motor before it gets too hot.
