Vacuum Leak/Hissing Sound
hakanerdogan
Car: 1997 Nissan Pathfinder VG33E Automatic
Well, nowadays I hear a hissing sound around throttle body. I tried to locate it by using old school methods but in vain. To be honest I am also not sure whether this sound is normal or a sign of vacuum leak.
I have a O2 SES light most probably due to lean condition.
And temporary power loss uphill climbs.
Any ideas welcomed. How do I detect it? Or ıts a normal sound?
https://youtu.be/K3UuttITAiI
MisterH
Car: 1999 Infiniti QX4
Couldn't really hear anything unusual from your video. Did you spray around the intake with starting fluid, or propane? What 02 sensor code are you getting? A failing upstream sensor will affect the running condition.
hakanerdogan
Yea I did spray a starter fluid, almost whole can which actually made me afraid may could catch fire, that much :)
If you say that vacuum sound is normal I will search the problem at O2 sensors. I am getting P0150 and P0130. I think P0130 is before cats, which is important as you said.
The performance problem I have is only uphill when the vehicle is under load. Not sure an O2 sensor cause that?
Thanks.
MisterH
I didn't say a vacuum sound is normal, I said I couldn't hear anything unusual in the audio portion of the video. If you have an upstream CAT error it will most definitely affect the performance under high load conditions, and going uphill is a good example of that.+
