When I had the vacuum leak it would idle at 400 mm Hg, but now it idles at 600 mm Hg. The vacuum leak was near the firewall. It was the one that hooked up to a censor, not to sure what it is called, but it was there.klattr1 wrote:where was it at and how much difference of vacuum did it make at idle?
Yeah, I used a homemade leak tester and then pressured with an air compressor. I will take a pic of it once I find batteries for my digi. It was kind of hard to find the leak because it had a rip at the metal connection, but once I pressurized the system I felt where the air was coming from.nissanfanatic wrote:Did you just pressure test it with an air compressor? And yes where was it at? I believe I have the same problem right now.
well at least you found it. whatever sensor you are talking about though.what did you do to fix it? clamp something, tighten something?fastpace wrote:
I just made sure it was clamped down and ran a new vacuum line to it.klattr1 wrote:well at least you found it. whatever sensor you are talking about though.what did you do to fix it? clamp something, tighten something?
Hey what's up man, I finally got a hold of my fsm to see which one it was leaking. It was the S.C.V. control solenoid valve. It has two vacuum lines hooked up to it and the one that was leaking was the one to the left if you are facing the front of the car. The S.C.V valve thingy is right on the connection of the o2 sensor. I think when I was pulling one of my a/c lines I might of teared it.klattr1 wrote:im just curious what sensor you are talking about. maybe one of the emission devices (BPT valve or solenoid).
