biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Wed Dec 28, 2005 6:53 pm
if you open the throttle the vacuum decreases, for the same amount of consumed air - as the cold start solenoid closes off it would make sense for vacuum to change some, but since the cold start only lets in a tad more (doesn't take much to raise the idle ~600rpm or so in neutral) air you'd see only slight variations.
No need for leak consipiracy theories but these can also cause the same symptom.
