goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Tue Oct 02, 2007 3:55 am
It sounds like they might have loosened the MAF connector when they took the airbox cover off to try and sell you an air filter.
The MAF sensor (Mass Air Flow) is the 6" long round tube attached to the top of the airbox. If you can wiggle the connector up and down more than about 1/4" or if it feels loose it needs an adjustment. As you wiggle the connector you should be able to find a sweet spot where the engine runs a little better.
Pull off the metal clip and the connector (the WalMart boys did replace the clip, didn't they?), check the pins for (green) corrosion and clean up as needed (any penetrant oil and a toothbrush). Tighten up the female pins on the connector by inserting a small nail/push pin above each of the tabs (2 per pin) and plug her back in. Connector should go on tight and not wiggle if you've done it correctly. It should run better. Let us know. Good luck.
