Vacuum/Boost gauge operation
SrS13
Car: 1990 Fastback, 1993 Convertible Coupe
I was wondering if my gauge was operating properly:
At idle it reads about 20 if I'm crusing it its below any boost levels.
I was wondering if that is normal
thanks any help is appreciated.
big jon's 240
Car: uh....football, cars, and um, cars!
SrS13 wrote: if I'm crusing it its below any boost levels.
HUH???If you mean that you are running 20 (vaccum) at idle, then yes that is normal. I dont understand the second half of your question.
SrS13
sorry I ment to say that when I am at a crusing speed my gauge does not mark any boost pressure it remains in the vacuum side.
SWIFT_DRIFT
is it a mechanical or electronic boost gauge and does the needle even move at all? more info please
SrS13
yes the needle moves towards the 0 but stays just below during crusing speeds. Im just wondering if that is normal??
and it is a mechanical gauge
Tai Mai Shu
yes it is, for me to maintin a constant speed I usally am at 11 vacumm, but give or take.
BuudWeizErr
-10 is about normal. Give or take a couple.
-18 at idle is normal. A little more if you have cams.
ucfz31s13
Car: Business/Networking/Web
You wont produce any boost until you reach certain throttle % to create enough exhaust flow to begin spinning those blades. Cruising you are barely on the throttle so it will still pull a vacuum on the gauge...
And BuudWeizErr: Isn't that backwards? I was always informed that cams decreased vacuum at idle because motor loped more?
lataz
z
SrS13
kool this is exactly what I needed to know Thank you Very Much
BuudWeizErr
DiscreetSpeed wrote:You wont produce any boost until you reach certain throttle % to create enough exhaust flow to begin spinning those blades. Cruising you are barely on the throttle so it will still pull a vacuum on the gauge...
lataz
z
I could be wrong, but I think I'm right.
big jon's 240
The amount of vacuum does depend on the cam, if you have a cam (aftermarket) with more overlap, you will have less vacuum, and vice-a-versa. Ive never heard of too much vacuum, the more the better, means everything is healty.
