Yea I know the clutch has nothing to do with engine in vaccum was only talking about it affecting the boost but I got you. We are going to bleed the dampener tonight and hopefully that helps. Also replacing a coupler that is between the turbo and the maf that is a little worn and may not be sealed all the way so that might be messing with my air fuel ratio. You can bleed the dampner the same way you would a slave right nothing special to do it?evildky wrote:We are talking about 2 different issues here, you car should pull vac at idle in neutral, the clutch has nothign to do with engine vacum. when you drive the car the vac will fluctuate up to zero then into boost depending on how much skinny pedal you're giving it, the less skinny pedal on the flatest surface will give you the most vac and the best fuel economy, the more skinny pedal, the steeper the grade the more boost you generate and the worse your fuel economy. a slipping clutch might limit how much boost you can make, and the more boost you make the faster you kill the clutch if it's slipping. When you bleed the hydraulics of the clutch you have to bleed the clutch damper as well as the slave, failure to do this could result in air int he line, the clutch nto fulley disengaging and bad things happeneing. The dampener can be bypassed usign a brake line from an S130 IIRC. I didn't think the jap cars came wiht dampners, i thought that was a US market thing?
No Mckinney says that happens with recirculating bovs that it has less tendency to stall and help with idle. Although on most of his cars they run atmospheric cause them and the customers sometimes don't want to go through the hassle of setting it up for recirculating. and they can run full vent to atmosphere or run a hybrid 50/50 and jim wolf was like doesn't even chance it. Although I bet for jim wolf since they are tuning a bunch of maf cars as well don't like the hassle of having to tune for vent to atmosphere bovs.evildky wrote:Whats confusing you? They said what I said, atmospheric bov's on a metered air injection system = a rich condition. The only thing I see here thats confusing is the implication that an atmospheric bov can "help with idle and less tendancy to stall". Not sure who said that but I disagree, I see no way possible for a bov to have any effect on idle unless you replace a leaky bov with one that doesn't leak, the iacv would be the itme to look at if you have idle or off throttle stalling.
Have you seen the pics of my car. your probably right even though mine is a 1987 I believe it is setup to recieve the return air.evildky wrote:You can not tune a meterd air car to not run rich between shifts with an atmosphereic bov.It'sa contradiction and anyone who says it can be done does not know what they are talking about, a lot of Z32 guys regurgitate this misinformation. The tuning is based on the amount of air being measured and if you are letting an unmeasured amount of air excape fomr a metered air system there is no way to correct for it period. Mckinney is a swap shop, they made their name making swap parts and pieces for those lacking the skills or energy to fab their own parts. Jim wolf made his name making nissan/datsuns making speed parts for Nissan/Datsun engines. Completely different businesses. I call BS on the statement that a bov will have any effect on idle, this would only be possible if there were a leaking bov or mating surface. Nissan metered air aystems that came factory turbo'd with factory recirc valves require very little in order to use an aftermarket recirc type bov verses an atmospheric bov as they are already set up to recieve the return air. Most ricers do love to hear the whoosh of the bov going to atmosphere. Early Nissan/ Datusn turbo cars wiht metered air EFI systems did nto come with any bov or recirc valve at all, in these cases it's more work to add a recirc valve than to add an atmosphereic valve but you can either do the job right or take a shortcut. I'm not a fan of cutting corners.
yea it's not necessarily accurate at the time when I put that in my profile we were putting in a gt30r turbo and getting it tuned from jim wolf with the 94 maxima ecu but s*** didn't work out that was the horsepower we were told we should get just forgot to take it down sorry. After the swap I was around around 300hp even with my big 60 pound rims. The steering wheel isn't exactly on the wrong side since the car was an import from japan. It came with an rb20 my mechanic of Plumb Performance swapped in the rb25 for me.evildky wrote:When all the intercooler piping has been replaced with aftermarket it's hard to argue that it too difficult to pipe in a recirc type bov. It's a lot less work to pipe in a recirc valve than to do the engine swap, or to convert to a vertical radiator. Your profils says 450whp, so what injectors, ecu and turbo are you running? The stock parts won't get to this level. I'm no fan of advertising estimated HP, either you know or you don't. Stock injectors turbo and ecy you'd be lucky to see 300 whp.
...and your steering wheel is on the wrong side.
