Vacuum air leak?
DRFT24O
Car: 1991 240SX Fastback
Im hearing this loud hissing sound coming from somewhere right by the intake manifold next to the valve cover. It causes my idle to jump, I dont see any vacuum lines here though, where should i look?
TogueDrifter
Car: 91 B13 SER
I had the same problem. Take a can of Carb. cleaner and start spraying. Your idle should do one of two things, raise or stumble. when I found mine it was the EGR valve and it stumbled, almost stalled actually because it was running so rich. Good luck with that!
DRFT24O
start spraying where
DRFT24O
DRIFTEADOR
where the noise is coming from coming from.
or you could try something like this fitted straight to your tb:zerothread?id=113785
use soapy water and look for bubbling
TogueDrifter
Car: 91 B13 SER
well yes, spray on the intake manifold, around it, where it meets the head.. so on and so forth.
