vacumme on intake
IanS13
what to do with them vacuum hoses connected to the intake close to the trottle body. there is one connected to the valve cover, one connected to a big hose that goes under the TB looks like it goes over to the EGR valve i don't know what do i do with them.
Modified by IanS13 at 2:00 AM 9/12/2004
Modified by IanS13 at 3:57 AM 9/12/2004
WDRacing
Can U snap a picture?
andrave
Car: 1989 Nissan 240SX Coupe
not talking about the coolant lines, are you? cause it sure sounds like it. you can block that off if you want, won't hurt anything either way. pic would help tho, ka24de has a rats nest of vac lines.
IanS13
sorry about the crappy pictures and yes my motor is very dirty am working on that.
andrave
the one that comes off the rubber coupler goes to your valve cover (can be taken out and vented) and the one that goes into the TB looks like one of the coolant lines (the one your finger is on). But from your pic its hard to get perspective.
IanS13
that one is not a colant line it's air line that goes into the stock intake look closely
andrave
does that normally go to your carbon canister? I can't remember... Do you have an FSM? mine has all the vaccuum diagrams, helped me a lot.
95_240sx
Car: My baby (car)
Idle Air Control.
Run that into your IC piping Before your throttle body so it can suck air around the throttle butterfly at ide.
Rick
IanS13
cool thanks man.
