vacume leak
240r
Car: 91 240sx
How would I find a vacume leak?
quiksilvia
Car: 95 s14 se
put spit on every part of every hose and it will bubble
PapaSmurf2k3
Site Admin
that would only work if the pressure in the hose was positive, and since we are dealing with vaccume, the pressure would be negative, so it would suck the spit in. Ive heard that you can buy a can of starting fluid, and spray at the hoses that you think might be leaking while the car is running. if the idle goes up, you have a leak there, if it doesnt, then you dont.
quiksilvia
Car: 95 s14 se
ur right papa...sorry i was a bit intoxicated at the time i wrote that.
