vacume hose near throttle.
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
The hose that makes a crazy 90 degree turn near intake on plenum. Does anyone have a part number for it.Mine seems to suck in on it's self.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
1996-q45-plenum-hose-diagram-t522393.html
I think the hoses are the same on your model, at least the one you are referring to
first glance it looks like 14860NB
black g50
Yup that's it. Dealer only item,or can one be made?
black g50
Can that be taken into part store to be matched up?
BCC93QT
1995 Infiniti Q45
Can be matched but I would just go dealer... 1409960U60
$44.25 + shipping
http://www.infinitipartsusa.com/Infinit ... 60u60-.htm
black g50
What is that hose's purpose? I mean besides a vaccume hose what is it for?
BCC93QT
1995 Infiniti Q45
I don't know but if you pull it off and keep your engine running I bet you can figure it out when something stops working
black g50
Anyone?
N/A Q45
Car: 94 Q45
The hose is for the pcv valve. I just made one as I had the same thing happen. No way in hell I would pay $40+ on one. You have to take the intake off to replace it didn't take me very long at all, but I don't know what your setup is. Pretty good chance not the same as mine so it might take you a few hrs..
kevindanielk
Car: 1995 Q45 Stock, except for the blues.
That same hose, on my Q, developed a large hole below the elbow and was sucking in lots of air, causing me to fail emissions because of a lean condition. I finally located the leak and replaced it with a piece of elbowed hose from the local parts store. Not worth paying $44 dealer price for such a common piece.
black g50
Kevin,do you remember the mesurements or part number?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
kevindanielk wrote:That same hose, on my Q, developed a large hole below the elbow and was sucking in lots of air, causing me to fail emissions because of a lean condition. I finally located the leak and replaced it with a piece of elbowed hose from the local parts store. Not worth paying $44 dealer price for such a common piece.
Geez so thats why the hoses under the plenum are ~$1000 for the kit. I hope none brake when I replace my plenum and runners this year (Swap them out for clean ones). Of course I can see myself posting back about a broken hose and how they were so brittle.... :frown:
kevindanielk
black g50 wrote:Kevin,do you remember the mesurements or part number?
Sorry, I didn't pay close enough attention to remember the size. I just took the old one to the parts store, where the counter guys let me walk into the back, where all the crazy-shaped and curved hoses were hung up. I just picked one that matched up and was the closest inside diameter size to my old piece.
black g50
Don"t have the old one,as I put a temp one on.Hose is too long guess I can trim it some.
kevindanielk
It's just a vacuum hose so any same size diameter hose that has a 90 degree elbow turn, and doesn't collapse in on itself when vacuum is present, should work just fine.
