vacum lines SCARY STUFF
achilles0t
im building my car presently and im just curious if anyone has any vacum diagrams. i am trying to eliminate as much of my egr vacum lines
95_240sx
Car: My baby (car)
EGR doesnt operate on a vacuum, although it is vacuum actuated, just let the egr stay open or something? :)
Learned that today from EZCheese actually :)
Rick
piratepete
Get rid of all the vacuum lines. Leave one for the brake booster, one for fuel pressure regulator, and one for idle air intake valve. Removed the scv too, if you have them.
QUICKFLOW240
Car: racing, cars, chicks, racing cars, racing chicks
how would you get rid of all the vacuum lines? Do you have to plug them?
piratepete
There are only a couple lines connecting to the manifold. There area whole bunch of t fittings and what not. Getting rid of all the emissions crap gets rid of the spiderweb of vacuum lines.
achilles0t
what about the sensors on the back of the head. there are 2 vacum sensors
maxpsi
I would talk to Russ out of Atlanta before going and pulling off all your vaccum lines. He is a genious when it comes to this. He has no emissions on his car i beleive. he is one of very few who has done this properly.
piratepete
You mean the egr and scv solenoids? Just leave them unplugged. On a '92 this doesn't trigger the check engine light or any codes. All the lines I have are brake booster and fuel pressure regulator after throttle body, and idle intake valve before throttle body. EGR is blocked off with a metal plate and liquid gasket. Instead of figuring out what you don't need, it's much easier to figure out what you do need, and get rid of everything else.
95_240sx
Car: My baby (car)
And if your going turbo, dont forget one for a boost gauge.
Rick
achilles0t
for the idle intake valve, throttle body, and fuel pressure regulator does the vacum line have to run through the stock routing. and i have a 91. you said on the 92 the check engine light wont go on. how bout on the 91
Bryce
if you don't hook up the vcumm tothe scv wont it stay closed all the time? wont it then be an obstruction? I know I should just pull it out but i can only do little projects at a time.thanksb
goldenchild
Car: 90 Nissan 240SX KA24E-t go bye bye, gotta another in the works
so all the lines you need are 1)brake booster, one for 2)fuel pressure regulator, and one for 3)idle air intake valve. Will there be a problem if i remove the hard lines on the back of the head. Can someone post a pic
Nathan
Shoot no, rip that crap out...I'm down to brake booster, fpr, and IACV...thats it. I have to hook up the wastegate and BOV but other than that, NO other emissions devices or the SCV. Once you eliminate the emissions bull****, you can get rid of the hard lines on the back of the head. When you get rid of the hardlines on the back of the head, just leave the two solenoids plugged into the harness, but not hooked up. That way, you can be certain the computer wont throw any codes.
andrave
Car: 1989 Nissan 240SX Coupe
alright here is a question, what are you guys using for T's and stuff? I saw a pretty cool idea, a vaccuum boss, basically its a distribution block for vaccuum lines instead of multiple T's.. nice and clean and easy to trouble shoot.
WDRacing
Good idea...
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
Hey nathan do you have a pic of ur engine?? Cause right now Im tryin to remove as much as possible. I got rid of AIV, EGR, but all those hard lines an stuff are what confusin me. Pics would help alot.
Nathan
The Nathan BADLY needs a digital camera...I dont have a picture that would show you what you need to see right now :( Besides, I'm still not quite done with the vacuum lines yet anyways, maybe I'll finish them tonight...
goldenchild
just wondering, dont you need the solenoid on the back of the head for the fpr on the fuel rail, I having vacuum issues with my car right now and i need help. The hard lines by the fuel rail are gone, aiv gone, egr gone, scv gone, pcv sill there, before i took the stuff apart the vacuum was at -10 on the boost gauge and now its at -20. I tried to cap everything, now im going to connect the solenoid back to the fpr on the fuel
Nathan
I know for the DE there is no solenoid for the FPR, it should just take a straight vacuum signal from the intake mani. The fpr is very simple in operation, it just maintains an equivalent fuel pressure to the vacuum or boost the manifold is seeing so that the fuel flow rates stay the same. (yeah, a terrible explanation I know). Hence, it should NOT have a solenoid going to it since there is no time it would need to be computer controlled to increase or decrease fuel flow.
SSS
I'm 99% sure that is the same with the E too, the FPR runs straight off man. vac/boost.
j-z
Car: 95 240sx
golden eagle makes a nice vacuum manifold. actually alot of companys make some nice ones. search for vacuum manifold on yahoo or something.
