rb250sx »
https://forums.nicoclub.com/rb250sx-u8777.html
Sat Apr 30, 2005 2:08 pm
Well, another weekend, another failure. I buit a boost leak tester but could not build up any pressure in the system. since i moved back to NY ive been working on the car in storage and dont have power so used a bike pump. I pumped for quite a while, but nothing. When i pulled the hose off the recirc valve i could def hear air going through the little bypass hole in there though when i pumped. So i just took every single piece of IC piping and reclamped them perfect and went through all my hoses. When i started it up it idled and i got all excited, so i let it run a while. Then i decided to rev it a little bit, and when it wouldnt rev very high i realized it was idling because i forgot to plug the MAF back in so i plug it back in and it still doesnt idle. So i then checked the compression, it was 160 across all 6 cyl, anyone know if thats what its supposed to be? And then i just sat there staring at the car for a while being mad haha. Also, i noticed if i unplugged a vacuum line, nothing would change, but when i plugged it back up it would idle well for about 2 seconds. The other thing is, before i put the engine in, i did have the plenum off, and i was kind of curious about the gap on the inside of the plenum where the gasket ended. I didnt know if that was supposed to be there or not because i didnt remember it, but i didnt look very hard b4 i took it off either. But i put the gasket back in and torqued it down pretty good, and that seemed like it would keep it sealed up pretty well. I asked on the forum a while back but got no reply, so i continued with the swap haha.
