vaccum hose configuration on bluebird
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
boost_creep
Car: 92 sr powered coupe,06 Spec V
im helpin a freind with a clutch replacement and have come across a few broken and missing lines.he has the charcoal canister still installed as well.should i just pull it out.(i did on my sr)if someone could explain where the lines go ,pictures would be awesome.there also another line between 1st and 2nd intake runner,where does that go?..its a 91 bluebird with top mounted intercooler.thanks much.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The large line on the charcoal canister runs to the side of the intake manifold. The small line on the charcoal canister runs underneath the throttle body. The line running between the 1st and 2nd intake runner go to the top of the BOV.
boost_creep
cool.thanks alot man.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
