RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Sat Nov 11, 2006 3:30 pm
Is it needed? If not, anyone got a vac routing diagram without it? Since I got it, should I use it? Is the wiring plug attached to it just hooked to a 12v source, or does it go to the ecu? Will the ecu miss it, if it's gone?
Also, that solinoid thing thats right next to the ignitor mounted on the right side......is there a way to bypass that? The actuator line is tapped into this along with a vac line.
I would like to eliminate some of this crap if possible
Modified by RS12Turbo at 6:44 PM 11/11/2006
