That's all Heavy Throttle does with their hotpipe.89 240hatch wrote:what i planned to do is drill a small hole and thread a brass fitting with a nipple on the other end.and of course use some threadseal.
So you have your top left nipple going to your fpr and boost gauge while you have the top right nipple(bigger one) going to the bov and boost controller?Taylor_Durdan wrote:why run your boost source from your pipes?
your piping actually charges up before the manifold so your wastegate opens prematuraly, thus taking away alot of drivebility. use the larger of the two vacuum ports above the throttle body as your boost source. the wastegate doesnt open as soon and the car feels a million times quicker! i had a sidemount for ahwile on my old setup and was using the factory nipple of my sidemount piping. i also had a screamer pipe on my turbo so you could hear when exactly the wastegate was opening. i decided to try and change where i got my boost source from and used the port above the throttle body and capped off the one on the pipes. and WOW! what a difference. i strongly recomend on a FMIC setup to run your boost off the ports they provide for you on the intake manifold. just dont use the one under the throttle body, in fact. cap it off.
Im going to try this out,Will let you know how it works for me.Taylor_Durdan wrote:why run your boost source from your pipes?
Ok,I did it and he's right the turbo spools a bit faster,about 300-400RPM's faster,And the turbo acts different it spikes at 9psi and then stays at 8psi.I like the feel of the car better now.What i did was run one line from the larger port on the right to my bov and put a T and ran a line to the wastegate.Thanks,for the tip Taylor_Durdan.Taylor_Durdan wrote:why run your boost source from your pipes?
