doridori23 »
https://forums.nicoclub.com/doridori23-u68081.html
Tue Aug 21, 2007 6:58 pm
a vac leak will lean the car out and shouldn't have a large effect on restart.
I would clean out your IACV (carb/throttle body cleaner), put a bottle of fuel system cleaner in the tank, inspect all vacuum line connections and check for rubbing on the entire length, check the air tube going to the IACV (bottom of the manifold and bypasses the throttle body), and inspect all air piping and hoses from the filter to the block assembly. Do you have a wideband, fuel pressure gauge or any other info on the problem?
