it should go intercooler nipple -> boost controller -> then wastegate not T off to both of them.VigVoodoo wrote:Here you go. This is how I have set it up on a few SR20DET installs.
I don't think so. If you do that it will cut all boost going to actuator, whereas my setup leaks boost so the actuator reads less than the actual boost.karmakaze wrote:it should go intercooler nipple -> boost controller -> then wastegate not T off to both of them.
