When you start getting 600HP out of your KA, let me know.Edub1 wrote:If you're building a drag car. If not, you're in for a lot of grief and aggravation and your car will be a hick mobile that will forever be a 1/2 put together work in progress. It's kind of pointless when you can get 600HP from the Ka.
Very true, but squeezing 600 from a KA isn't a bolt on affair either. I'm all for an LS1. I've heard about them selling for about $1K so that should be some incentive to go that route.Edub1 wrote:Swapping a motor into a car in which it doesn't belong is not a wise thing unless you have the ability & patience to do a lot of fabrication. There are much easier rows to hoe.
Yeah, I know that guy and it is pretty bad ***. And I dont see how it would be much different if you did the same in an S13. He doesnt have any major problems, and I dont think anyone putting it into an S13 would either.zippitta wrote: Cost:performance = not worth it. You wouldnt have any traction even if the motor was stock. It would setoff the F:R weight ratio too much.
On the other hand........
It would be bada$$...I would give mad props if you were to follow through and complete it. There is a dude in Pensacola with an LS1 RX7. I am sooo jealous....
OK, there goes that idea sailing into the abyss.IWannaS15 wrote:^^ The LT5 from the Vette ZR-1. Very expensive (like $15,000+ for a crate motor) and very rare...
