Car performs well when its cold (more than the usual improvement that all cars see) and poorly when warm is consistent with 2 things in my mind :
-Summer knock with subsequent retardationOR-Cooling system inefficient for one reason or another (for example radior clogged , not flushed ever,.. or filled with partial fill of tap water, which wouldhave promoted clogging), and the subsequent higher temps seen by ECU, would result in switching to a different map for running the engine.
Dennis has mentioned the exact temps at which this occurs on these pages a couple of times.
It is progressive, the warmer the coolant gets, in steps, the ECU will retard power, to protect engine.
Fred..
