Wanting a certain sound is ok and all, but that takes a backseat to your performance goals for the car. The reason why some pick a V6 or V8 rather than the overhyped SR20 is because the the broader powerband than comes with an engine that has larger displacement.zerocounter wrote:I just want my car to sound like this beast: http://www.youtube.com/watch?v=uMj3NRPWFv4
*chants*simmode1 wrote:Wanting a certain sound is ok and all, but that takes a backseat to your performance goals for the car. The reason why some pick a V6 or V8 rather than the overhyped SR20 is because the the broader powerband than comes with an engine that has larger displacement.
For example, you might build an SR that makes 400hp. But at what RPM does it make that 400hp? And how much torque is it putting down? Almost assuredly, a V6 or a V8 will make that same 400hp earlier in the powerband and for a longer duration throughout your rev range. This is why ppl say: There's no replacement for dispalcement. You might argue that turbos on a small displacement motor will bridge the performance gap, but if you put a turbo on the larger dispalcment motor, you're right back at square one with the V6 or V8 coming out on top.
Personally, my preferance is to use a lightweight V6. It'll have good weight distribution and ample horsepower/torque for our little toy cars. Motors like the VQ series are perfect for the S-chassis, IMO.
To bad the search doesnt work.Silvia_Ks_90 wrote:yes, go to the hybrid engine section, or simply type LS swap 240 or S in the search bar, welcome.
btw, V8's arent the only big engine people are swapping in....
i have been trying to understand this as well.zerocounter wrote:is there a particular reason why they didn't go with the SR20 turbo setup?
the D1 guys have proven the SR20 can win...
really?jake! wrote: i have been trying to understand this as well.
+1
It doesnt get anymore pratical than a motor thats was meant for the s chasis. Sorry but the ls1 was not, and that swap is far from pratical. Neither is any motor that didnt come stock in the chasis, but the sr and ca are as close to stock as you get. I still dont see why a** tons of hp are neccesary for a drift car.urcaptnspeaking wrote:SR20 may be an ideal upgrade for an s chassis car,but they aren't for EVERY car... there are far more practical engines depending on their uses.
On paper it seems like a good plan but finding a ls-whatever motor set(engine, transmission, wiring, and ecu) for less than $3000 is getting more and more difficult as the popularity of the lsX motors has gone through the roof, and most swap kits are in the $1200+ range, and most don't come with headers so tack another $500-$800 to the cost of the mount kit.urcaptnspeaking wrote:SR20 may be an ideal upgrade for an s chassis car,but they aren't for EVERY car... there are far more practical engines depending on their uses. Obviously the Nissan V8 was their choice (and Im sure for good reason) and if I recall (not sure if it was his car or another v8 swapped Z) but it was close to 500 horse.
SR's can break and be "junk" just like ANY other engine on this planet. If an engine,any engine, is built right and taken care of it can be favorable to you. further, the same engine could be nothing but a headache to the next guy.
You do realize a stock SR is in the mid to lower 200 horse power range....right?
you could spend close to 4k (including engine set) to put an SR are a reliable 350 horse power range , or swap in an LS1 a few bolt ons for the same price and have a naturally aspirated 350 horse power with larger displacement and more torque.
/story
