KB Services »
https://forums.nicoclub.com/kb-services-u67310.html
Mon Jun 18, 2007 7:37 pm
Started out as a R&R on a water pump. Didn't set TDC so started from scratch. Pulled the intake, valve covers, loosened the rocker studs and rolled the crank to #1 TDC. Set the cams at the alignment marks and replaced the belt. While the plugs were out I rolled motor over a dozen or so times with no binding.replaced the distributor and set it at #1 wire ( I never pulled the wires from the cap so location is correct) put everything else back on and fired it. Fired off okay but on the road under load it has valve chatter or knocking. Reset the timing, moved it a tooth each way and it's still there. I done WRONG
