DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sat May 31, 2003 9:33 pm
It all comes down to physics. F = ma. Ignoring differences in gearing, assuming similar efficiencies, a relative comparison off the line can be simplified by comparing hp to weight ratios. So it seems reasonable that your Q can beat a 3000lb car putting out 200hp, probably to any speed or distance. But gearing does make a difference and can either help or hurt depending on your speed. I'm amazed by the Q's power, but I'd still be wary of challenging a notably lighter car putting out 260hp. Top speed is an entirely different story, since weight has no impact. Drag is a function of the square of velocity, so if your car's top end is higher overall, drag will impact the other vehicle substantially more the faster you go. I don't know what a G35 tops out at, but if you had to race one, you'd probably have a better chance racing to 120mph than to 80mph. Good kill story BTW.
