yeah, when i actually get started my goals are about 300whp, just enough to mess with the V8s and riceboys around here (the import thing is just now starting to really hit oklahoma i think, so most of the people are still in that "riceboy" stage)rbsileighty wrote:If you don't plan on making a lot of power and you use a short (bottom of fins to top), wide intercooler... it might work. Try looking into a new Saab 9-3 intercooler and modify the endtank inlet/oulet locations. Blackstone makes the cores for those, or at least they use to, and they make a quality unit. Take some measurements first.
See my post about moving the radiator... might help out with a V-mount.
rbsileighty wrote:I think he is talking about putting spacers in the back of the hood to prop it up and make a "heat extraction hood" out of the stock one.
it isn't just the increased airflow to the radiator, but you get better throttle response (if it is properly set up) because you will have alot less IC pipingjbsr20fiend wrote:I'm not an rb guru, but do you really think the v mount set up is necessary. If airflow is that important I think apex makes an intercooler that flows more air to the radiator. I cant remember the model of the top of my head.
yup. i think if the cowel was directly over the intercooler (or as close to being directly over the intercooler) as possible it would work more effective getting the air out of there faster instead of it hitting the bottome of the hood then traveling the length of the engine bay to get out of there. instead of it hitting the windshield and causing turbulence it would get sucked out of the top of the hood and then slipstream over the rest of the car (if that makes sense)rbsileighty wrote:I think he intends for the intercooler and cowl to function like the Sard Supra:
93RPS13 wrote:what ever floats your boat it your money right, personally i like the low profile type of car
yeah, that is what i am thinking without a bunch of headache. but i think i can reach my HP goals with an sr20det for about the same cost as an RB20/25det so i may try it out with that, still not sure though. but on a good note, i may have found me a shell to start with for about 300 bucks, waiting to hear from the guy.vududoc wrote:the hood vent is nice.or grab a old windshield washer resevior along with the pump and create a misting system. total should be about 60 bucks in parts. There really is no room for the v mount
yeah, no doubt, the swap and the car has gotten alot of attention since SCC did their build a sivlia for 3000 bucks and all of the coverage of drifting events and stuff. i have wanted one for about 4 years now (since my senior year in high school) and i am just now where i may be able to actually get one, so i have been researching and finding everything i can since then, so hopefully i will make a wise choicevududoc wrote:GL on you shell....i just got rid of mine for 500. there were alot of people trying to get it before the other person...turned into e-bay.
