V-Mount intercooler/ SMIT
vds89
Car: Nissan s13
I've been doing some research because im in the proccess of rounding up parts for my soon ka-t and the front mount intercooler is alright but im not tring to get noticed just want to keep my stock look, I did some research and couldnt really find any answer becasue I either want to do the v-mount or the side-mount but i got a couple questions, what kind of modifications would be needed for the v-mount? I've seen them on some s-15 but i could not really get a close detailed picture to see the setup,I know as far as modifying your radiator but im assuming there are a couple other things, and for the sidemount is it a direct bolt on with a t/25 bottom mount manifold or would I have to modify some of the pipeing to fit? appreciate you for looking..
Side-mount
V-mount
DMan II-40
Car: 1995 240SX SE
for the v-mount it will take a lot of fabrication to get it o fit in there and stuff, and u have to make a hood air duct fit up with the intercooler to actually make it worth it. If there is no hood air duct to it then there really isn't a point to have an intercooler. I say go for the side mount. much easer.
eazye2000
Car: S13 KA-DET
^ What he said..
They are a pain in the azz to get setup, and to get them to work properly.
Just a suggestion, but this is what I did. Just trim out the front bumper, and cover with 'ricer-mesh'. Kinda stealthy/stock looking.
Before:
After:
WDRacing
Your best bet for a IC if the FMIC isnt an option is the water/air cooler.
WD
egan
vds89 wrote: want to keep my stock look,
big hole in hood to let air out from IC.
vds89
Car: Nissan s13
eazye2000 wrote:^ What he said..
Before:
After:
that fmic doesnt look that bad not trying to be rude or anything, I dont know if im seeing wrong but did you relocated your powersteering, and also what is the name brand of your fmic
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
V mount is for off road use only!! If you get pulled over and your radiator support is cut up your car will be declared unroadworthy and will be towed on the spot.
eazye2000
Car: S13 KA-DET
My FMIC brand is XS Power. Was an eBay generic that has worked pretty good so far. I didn't mount it as secure as I wanted to. But the way the bumper is held on by the bottom, it helps support it if anything was to come loose.
Yes, my power steering reservoir was relocated to that empty spot by the clutch master. Looks stock huh?
I know I'm not utilizing the whole Intercooler, but it does make for a little more headroom and keep everything from getting heat soaked. I also have two electric fans on the back side of my Koyo. One 16" for a main fan, and a 12" as the A/C, or 220 degree helper.
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
Paint your I/C black. Mine is hardly noticeable, you wouldn't even realize it was there unless you were looking for it. on top of that, it looks like a black radiator or something.
2FourTee
Car: 96 240sx - Supercharged ka24de
PantherRacer wrote:Paint your I/C black.
That's what I'd do (and what I plan to do on my car).
DevilMB3017
Painting an IC black makes it heat up a little more and become less efficent. Also, if you do, try to get an extremely thin coat.
I'd recommend 'tuner mesh' in black to hide an IC myself...
DMan II-40
Car: 1995 240SX SE
DevilMB3017 wrote:Painting an IC black makes it heat up a little more and become less efficent.
Actually there was a website that I saw that tested that, and the black had little to no effect on the intercooler. The tiny amount of the difference it made didn't effect performance at all.
boznuttz
Car: MS13
Radiator paint FTW
480sx
Car: 1996 Pearl White 240sx
Wasnt just any website either, im thinking that either turbonetics or Garrett did that research. I know it was a huge name that said a light coat of black on an IC had little to no effect on its cooling efficiency.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
yup garret did it.
Garrett Faqs Page wrote:# I want my car to remain a sleeper/stealth. Can I paint or anodize my intercooler so it is not easily visible?Yes! It is not uncommon at all for an intercooler and endtanks to be anodized black to keep attention away from the car and help it maintain a sleeper appearance. A very light coat of paint on the core and endtanks is also another option, usually much cheaper and easier than anodizing, with a negligible performance loss.
2FourTee
Does anyone have the link to the testing Garret did on this?? I've heard so many people talk about it, but I have yet to see it myself.
DevilMB3017
Well alright then. I might be painting my IC black soon...
Good job calling me wrong
