the code, SAVE15 works. But not sure for how long. I just ordered 2x 12 LED stick-on strip lights and this #194/#168 socket adapter to hook the lights into the trunk socket:
http://www.v-leds.com/Interior-LED/Trun ... 10517.html
@Jake7, the brake/tail lights use #3157...backup lights use #194/#168/#921. Basically the dome, map, door/step, 3rd or high mount stop light and backup lights use the same bulbs...#194/#168/#921 are all interchangeable.
Yes the LEDs from v-led.com ARE brighter than stock, but the more expensive ones are the brightest.
I just bought these #3157 for the tail/brake lights. I had ones earlier that I bought but were only about 35 lumens when you depress the brake.
http://www.v-leds.com/Exterior-LED/Brak ... 3-1-2.html
The #194/#168 I had in my map and dome lights were only 35 lumens, but these I just put and are 105 lumens!!
[url\]
http://www.v-leds.com/Interior-LED/Dome ... 3-1-2.html[/url]
Also if the bulb doesn't work when you first plug it in, just reverse it as the polarity could be reversed....
