IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Tue Mar 23, 2004 9:30 am
first off, the pic doesnt work.
if the turbine output is round with a grooved lip, then you need a V-band clamp, and a downpipe made with a V-band flange to mate with the turbo.
if the turbo has a v-band connection, then it is also external wastegate and you have to figure out where to place the external wastegate, and how to plumb it.
keep in mind, v band clamps are expensive. the band you need will probably cost like 75-100$
