V-Belt Snapped - Car Overheated - Have Questions
skydan12
Car: 2006 Infiniti M45 Luxury
Hello, the long v-belt snapped on a highway, AC went out and car overheated a little. No fire or anything melted as I can see. Now I am trying to fix it and have a few questions. Please help.
1. Much of coolant is gone. Do I just add more or need radiator flush to remove old coolant?
2. Is remaining coolant bad after vehicle overheated?
3. Is engine timing affected when belt snaps?
3.5 Do I need to adjust timing somehow?
:confused:
Thank you.
2006 M45 with 55K
1st35
Car: 2007 M35x 2000 Lexus RX300 1998 Toyota RAV4
1) Not unless the cooling system was a mess beforehand, 2) No, 3) No, 4) No.
Be sure to use a 50/50 mix of the correct coolant. Peak makes a version called " Original Equipment Technology" for Asian Vehicles, Extended Life Green. I believe I got mine at Autozone or O'Reillys, maybe Walmart. Mine is an 07 model, not sure if the 06 used extended life.
skydan12
1st35 wrote:
Tue Jul 20, 2021 5:24 pm
Thank you very much 1st35! :mike
PalmerWMD
Car: 2004 350Z
Great thread.
Questions asked---> Questions answered quickly and correctly :yesnod
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
PalmerWMD wrote:
Tue Jul 20, 2021 6:08 pm
Great thread.
+1 :yesnod
The only thing I'd add is that blue and green are completely miscible if you don't mind turquoise. Just don't mix orange, that gels the cooling system and makes a giant mess.
skydan12
Thanks a lot PalmerWMD & VStar650CL. :yesnod
EdBwoy
skydan12 wrote:
Tue Jul 20, 2021 3:38 pm
2006 M45 with 55K
I am glad you were able to come out of the incident fairly unscathed. I hope you are able to get back on the road soon.
That being said, I'd like to offer a different perspective, or just supplemental information for those who might be interested:
You could get by by topping it off, but in the long run, I'd want to start afresh with a known 50/50 mix so I would drain and refill the system.
When you say much of coolant is gone, where exactly are you using as a reference point?...the overflow reservoir?... the filler neck? How much coolant did you need to add back in?
Is the remaining coolant bad after a vehicle has overheated?
It depends on how it overheated.
My rule of thumb is that if the radiator cap lets go or you see steam coming out of the system, then I would just flush it as a minimum.
When it overheats and loses enough coolant (or rather the water content in the coolant), you are likely to alter the water/antifreeze ratio in the coolant. Plus, the salts start precipitating and depositing in the system. That is getting into the finer details, and as I said above, sometimes any variances are barely noticeable unless you are very discerning of such changes.
Again, since it's hard to tell exactly how much water is lost when it has escaped the coolant system, I just play it safe and replace it all.
Thankfully your timing isn't affected by the belt snapping. What you snapped is called an accessory drive belt which drives the water pump, alternator, AC compressor.
A timing belt keeps the camshafts in sync with the crankshaft. The timing belt is typically hidden inside the engine, and for the M45, they actually use a timing chain.
Anything else I might need to know?
Yes.
Accessory drive belts don't just snap for no reason. They are extremely durable and when they fail, that is usually a symptom of some other underlying issue. It would be nice to verify whether:
  1. An accessory or pulley in the system is bad and catastrophically damaged the belt.
  2. The belt was old, worn and stretched beyond its safe operating limits. At which point it will either slip or break.
  3. Looking at the damaged belt will give a decent mechanic an idea of how it failed. Sometimes, a slipping belt will abrasively sharpen a pulley to a point that any other belt you install will be chewed shortly after.
I am not saying any of this to scare you, but rather to suggest that you have someone knowledgeable look the car over and address any underlying issues, lest it leaves you stranded again.
It would also be a good opportunity to address any issues that may have arisen as a result of overheating the engine.
skydan12
Wow! What a wealth of information! Thank you EdBwoy.
I judged lost coolant by the level in the overflow reservoir. Radiator cap did not pop and no steam. The engine temperature was high when pulled over on shoulder. I haven't had a chance to add coolant yet, I am waiting for belts from RockAuto to get to me first. I will add coolant that I have to check the vehicle and if everything good, will do flush and fill with Peak 50/50 for Asian cars.
The belt must have been old. There is no way to tell now as it fell apart into threads and was wrapped around every pulley in the front. I will run my fingers along surfaces to check pulleys when installing new belts.
Thank you very much to all, you helped me a lot.
EdBwoy
Ok, cool. It doesn't sound like it was a catastrophic failure. Maybe the "lost" coolant in the reservoir, was due to the coolant level dropping over time and not immediately related to this event.
Once again, good luck. When you get to the coolant refill process, remember to check the filler neck as well. Although, in my opinion, it shouldn't be a tough job as the 4.5 engine is very easy to refill with coolant. It is good at self bleeding of air bubbles.
I'll link this info for the benefit of anyone scrolling through - should-you-use-blue-or-green-coolant-ye ... 22612.html
skydan12
Great, great news! The car works great with new belts. I replaced both main and power steering belts. Belt tensioners were really tight and moving freely, I kept them. I added about a gallon of green coolant to reach recommended levels. I will flush the rad and replace coolant when temps go down here in FL. Thank you all who helped me and I wish you all the best!
1st35
Glad it worked out! Thanks for following up and letting us know.
