98s14inaz »
https://forums.nicoclub.com/98s14inaz-u3758.html
Thu Sep 22, 2005 10:21 am
check your fluids, check brake booster line for air leaks, check for puddles of fluids, check for leaking calipers. Check you pads and rotors to make sure everything is in spec. Also when you bleed your brakes make sure you follow the fsm and do it with the car on. Get one of those brake bleeder kits with the clear hose so you can see if any air bubbles are coming out. Good luck.
