DRIFTEADOR wrote:water injection isn't constant so I wouldnt advance base timing anymore than a non injected setup. if you have electronic timing control then yeah, advance it where it'll be activated.
I'm not looking for gains, so I wont advance it, the gain would be preventing my ECU from retarding it.
DRIFTEADOR wrote: i'd use a higher pressure pump. the more pressure the better atomization you'll get.
Those pumps are uber expensive like 200+, while the RV pumps are like 70-80I'm compensating for lower pressure by getting a smaller nozzle (compare to one used in FI water injection kits)
DRIFTEADOR wrote:washer fluid leaves deposits that'll eventually clog the system; use distilled water or water/alky in the winter to keep it from freezing.
I have distilled water in there right nowI'm in south cali, in never drops below freezing
DRIFTEADOR wrote:if you forget to fill the reservoir your pump wont blow up but your motor might
LOL, that would be the day
Nismo_Freak wrote:Advancing the timing by more degrees on an N/a low compression engine can actually lose power.
You aren't adding back timing you otherwise would reduce because of combustion pressure.
Long story short, why bother, you won't gain anything by it.
I tried different timing setups on my KA back in the day, I found about 2-3 degrees on 93 octane worked well. Any further advance and I could get low end knock, and it really didn't run any faster.
The reason you have carbon built up like that is you have a stock KA map. They run rich up top.
Well less work for me then, I’ll just leave the stock timing.Seeing how the compression is at 101% right now at 88K miles, that's pretty good, better higher then lower, I hope the water injection will clean things quickly
