PcCypher wrote:Also can you just put in the awd transmission and dent in the tunnel like fullrace did on the R14 and just not connect the front drive shaft? Will it stay in rwd without the hydrolic and electronic attessa system?
zer...66310
this thread i made is pretty new. try diff searches next time.
fyi i believe anything is possible, but will it be worth time and money?
secondly what u jus did is something i hate when others do...ask a question then give the answer, like sorta telling us to agree. Then y ask? sorry jw
kuuligan wrote:
so you're saying that the transmission on R33GTR and R33GTST are the same? Isn' the GTR a 6spd?
Also, will a RB26DETT engine fit w/o modifications on my existing RB25DET transmission?
1st only the r34 gtr is a 6spd.2nd yes they will, read on...
they are similar. not sure about internals but externally they mate up no prob. ie RB25DET transmission to rb26 engine. in fact i think after all my reading that it seems all rb trannies are interchangable with one others ENGINE block.
i got that conclusion with hearing that people use rb25de, rb25det, rb20 transmission to rb26 engine. SO the mating surface has to be the same. however the bell housing that connect to transmission are diff. atleast the 25 compared to 26.
i've never tried myself so take it as u will. if im wrong on anything someone please correct.
