Using the 180sx digital climate controller
S13 King
Car: cars, performance, girls
I was looking at the 180sx digital climate control, and was curious if anyone has one in their 240 that works, and what all had to be done for it to work. I have a 92 240sx LE if that matters.
DOOM240sx
Car: 93 Hatch too Custom 4 u
Well i dont have one personally....but from what i gather is.. the digital can be wired up.. but wont work 100% the reason being something with the way the USDM 240's hot/cold adjustment is manual as in it's a lever that has to slide...the digital works with climate control and really just doesn't have the hardware to make it work properly.You would have to set it to all the way cold or hot no way to control it. I had inquired about this that's how i got this info...hope it helps.
DOOM out
S13ChucKAT
Car: asd
no, there is like.. 15 sensors stuffed through teh JDM dash, if you get a front clip, swap the entire dash over, and all the sensors will be installed.
S13 King
gezz, that seems like a biotch..........I think i'll skip on the JDM gear, as cool as it is but nah.
