Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Mon Jan 24, 2005 3:55 am
Slave bleed screw on S13 is 8mm...caliper bleed screws are 10mm.
I know because I just broke mine off in the slave cylinder yesterday. Word of advice; soak that sucker in WD-40 before you start twisting, it'll break pretty darn easy if it's stuck.
I'm getting a new slave cylinder through Midway's parts special, $35, and clutch speedbleeder and SS line from SPL, $27. Figure since I've got the damper removed already, might as well put the SS line in.
Modified by Meantime at 2:04 PM 1/24/2005
