ok i c, i was always told they were exactly the same but i trust what ur sayingDjPantsSpecR wrote:well thats because they technically are..... kinda
s14 trannies are actually a bit longer due to this weird metal and rubber collar thing they put on at the tailshaft. Trust me i know.... you have to cut it off if you want to put an s14 transmission in your s13. it took me at least a half hour to figure out why i couldnt get my drivcveshaft to fit the first time.
and as stated before the only other difference besides the different speed sensors is that there is a Crank Angle Sensor in the top of the S14 bellhousing. If you wanted to put an s13 transmission in your s14 you would need to drill a hole to fit this.
I'd love more info on this. I have a S14 KA in my S13 right now, even if I swap a S13 Dizzy and run S13 ECU and Harness, I'll still need to have a S14 MT? I have an S13 one on now. I'd LOVE if someone can confirm or deny this. Could be quite a setback for me.DjPantsSpecR wrote:you can use an s14 transmission on an s13, but not vice versa. S14 trannies have the CAS in the upper bellhousing, whereas S13s have the CAS in the dizzy.
check to make sure you have fuel pressure, your injectors are opening, compression, and spark. if you have all that check that you have the timing correct.240killer wrote:hey, i may be having a sililar problem with my s13, i have s14 motor and head, everything else is s13, we have no start at all, cranks but no start.if you can help please lmk.advise is greatly appreciated, i need my car back!
