jasejase wrote:As long as it meets the factory requirements, they can't force you to use anything. Talk to the service manager. I've always ran high end fluids in my performance cars that would cost 2-3x the dealer crap, inclusive of motul and Redline. Dealer never said a word. Ask what their concerns are and what it means if you sway from their advise. Ask for it in writing.
I would not consider Nissan-Matic S fluid "dealer crap".
On the contrary, it is probably by far the best formulated fluid you can use in your Infiniti M for longevity of the unit.
The dealer is not forcing you to use Nissan Fluid.
You are free to use whatever you want to use, just do not expect them to do the service for you, or to warranty any unit using an aftermarket fluid!
In addition, it is not the dealer's obligation to research after market fluid manufacturer claims of compatibility. They do not need to, they are the original source of OEM fluid, and that is all they will use to service your transmission.
Here it is in writing from a 2009 Infiniti M Service manual:
CAUTION:
• If Genuine NISSAN Matic S ATF is not available, Genuine NISSAN Matic J ATF may also be used.
• Using ATF other than Genuine NISSAN Matic S ATF will cause deterioration in driveability and A/T durability, and may damage the A/T, which is not
covered by the INFINITI new vehicle limited warranty.
I am not saying Motul, Redline & the like are inferior fluids, I am sure they are very high end. The question might be performance vs longevity.
Motul, Redline & the like might be better suited for performance applications, but what is the trade off?
I do not have the answer to that, and I am not into performance, so for me OEM fluid is all I would consider.
For others however, needs might be different!
