Using BG44K
96'er
Car: 1996 Q45
I have been reading some of the posts regarding the use of BG44K and I had a few questions.
1. Why does the oil need to be changed after the 2nd can of BG?
2. Why does the fuel filter need to be replaced as well?
Reading Jesda post, http://www.q45.org/roughidle.html he mentions using BG every 2 months to help keep the fuel system clean.
I want to add the BG44K to my normal preventative maintenance for my car.
Skibane
Car: 2000 Q45 AE 110K
96’er wrote: 1. Why does the oil need to be changed after the 2nd can of BG?
After running through a tank of fuel with 44K in it, you'll probably notice that the oil looks a lot darker. This happens because as the 44K dissolves deposits in the intake tract, a lot of the residue from those deposits ends up in the motor oil - Not good!
Quote »2. Why does the fuel filter need to be replaced as well?[/quote]The 44K tends to "loosen up" crap in your fuel tank, some of which ends up in the fuel filter - Also not good!
96'er
Car: 1996 Q45
So every two cans of BG44K or two tanks of gas, I need to change the oil and fuel filter?
Q451990
The idea behind changing the oil, is a theory that the BG44K can leave a residue on the cylinder walls that can get pulled down into the crankcase by the piston rings. I personally don't think it's a huge deal - in fact I usually put the can in after an oil change because I forget to do so before hand.
The idea behind the fuel filter is that you're going to loosen up some deposits and scale in the fuel tubes, and possibly some deposits will be returned to the tank via the return line. I would replace the filter once or twice per year after the initial BG use. Are you planning on using the 44k in every tank? I would say it's overkill - but that depends on how horrible your gas is, I guess.
Heath
qship96
Car: 1996 Infiniti Q45
[QUOTE=Q451990]The idea behind changing the oil, is a theory that the BG44K can leave a residue on the cylinder walls that can get pulled down into the crankcase by the piston rings. I personally don't think it's a huge deal - in fact I usually put the can in after an oil change
As does EVERY professional tech when using BG44k-do you really think they tell you to come BACK for an oil change a tank of fuel later AFTER they service your car???? I bet 99.99999% of bg44k is put in customers tanks AFTER a full service including oil change!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
In part it is the idea that some of the super strong detergents may end up in the crankcase and accellerate the shear failure rate of a crankcase of used oil.
Skibane
Since the Q seems to start "craving" a can of 44K at just about the same interval as when an oil change is due, it just works out handy to run through a full tankful of 44K right before the oil change. Since you're probably going to be doing the work yourself, it's no inconvenience to do it that way.
I agree that the fuel filter probably doesn't need to be changed as often as the motor oil. However, on a new-to-you vehicle, after that first can of 44K - most definitely replace it, since you don't know what kind of crud is in your tank or how long it's been accumulating there.
qship96
I only use it about once a year,even though there are 5 cans on the shelf currently-never notice any real difference-guess thats a good thing?
twebster725
Car: 2008 Infiniti FX35 AWD
Is your gas mileage supposed to get worse when you use BG44K?
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
What? If anything, it gets better. Better spray pattern from your injectors, better emissions, more cowbell, better mileage, everything.
How do you figure worse mileage? If that was the case, why would anyone use it? People swear by BG 44K and would drink it if they could.
Q45tech
The mileage is controlled by O2 sensors within their +-20% range.
If all 8 injectors are functioning unlikely that BG44k will change anything mpgwise unless you have a misfire.
twebster725
What are symptoms of a misfire? We changed the spark plugs over the summer, but I don't think we checked to see if the injectors were actually working.
At 190k miles the O2 sensor is a probability. How hard are they to replace?
Another factor is probably the severely degraded front tires I just replaced over the weekend.
Of course, it may all be in my head too.
Haitian_King
I think symptoms are rough/uneven idle. I might be wrong.
NightRiderQ45
Car: 1998 Infiniti Q45
Haitian_King wrote:I think symptoms are rough/uneven idle. I might be wrong.
Hey Haitian. Have you been able to win some BG44k off of eBay yet?
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
When I used BG44k I could tell a real difference in performance. I gave some to Jeff Williams and he said he couldn't tell much. I figured he just keeps a cleaner Q.
I have a can just waiting. Last time I used it on a long trip with 3/4 gas. Should I just go ahead and use it or wait for a road trip?
NightRiderQ45
AlabamaDan wrote:When I used BG44k I could tell a real difference in performance. I gave some to Jeff Williams and he said he couldn't tell much. I figured he just keeps a cleaner Q.
I used my first can on Nov 4th. I will use another in Feb. since I will be putting Chevron Techron in for December and January. BTW AlabamaDan, can you say 6 YEARS IN A ROW LOL!!! Man, I love this forum!
AlabamaDan
1998 Infiniti QX4
You may have six (wins over Bama) but we've got 12 (national championships!) We'll get you next year.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Any issues with BG44K with a turbo? Obviously no change if using it in the fuel but in the oil there would be...
Haitian_King
I stopped bidding. I decided to just buy a can right before my next oil change. That's coming up soon.
Haitian_King
I know BG makes an oil additive. The 44K is for the fuel system. The only product I know that can do the fuel, air system, and oil system with one can is Seafoam.
Jesda knows more about it than I do though. I've just read a couple of posts here and there on other forums.
96'er
Car: 1996 Q45
So if I understand all the comments, it is best to change the oil after the 2 can of 44K to prevent any other problems from cropping up.
Haitian_King
I guess. I plan on changing my oil after I drop in one can. 2 cans, 6 cans, it's good to change the oil after an application.
Skibane
I'm using just a single can of 44K. The instructions say that it treats up to 20 gallons of gas, which is pushing it a little bit on a Q with 21-1/8 gallons of gas in a full tank. I prefer my mixture a little more concentrated anyway, so I dump the 44K in a quarter tank of gas, and then immediately add another quarter tank of gas to mix it up (i.e., 1 can for 10 gallons).
Haitian_King
Is there a negative effect if you were to put in 2 cans in a full tank?
